Hello Guest it is October 24, 2026, 07:10:24 PM
Author Topic: Support M10/M11 commands  (Read 32526 times)
Re: Support M10/M11 commands
« Reply #10 on: May 11, 2015, 02:21:49 AM »
Thomas, I don't use mach3 THC. I developer of the Neuron.THC.
Command M10/M11 or M10Px/M11Px use in g-code laser cutting machine, plasma, oxyfuel...
This command is regular Mach3 function and I hope It's support by CSMIO.
Smooth stepper support this commands and has separate settings for this in the configuration menu. Full support has and  HiCON motion controller.
In Mach4 we need this command too (M62/M63 -  Mach4 embeds the IO into the motion data that goes to the motion controller and then to IO ports)
Thanks!!!
--Andrew
Offline TPS
  •  2,627 2,627
« Reply #11 on: May 11, 2015, 12:44:18 PM »
Hi Andrew,
you are absolutly wright.
tested on my -M and -S machine, not working,
only with PP.
looking forward to CSMIO answer.
Thomas
« Reply #12 on: May 11, 2015, 12:46:05 PM »
They answer CSMIO not support this. But it's coming soon....... :)
--Andrew
