Hello Guest it is November 22, 2026, 02:04:09 PM
Author Topic: need some lua help  (Read 33904 times)
Offline dude1
  •  1,253 1,253
need some lua help
« on: May 02, 2015, 04:12:40 AM »
I am going through the M4 scripting manual have got up to the automatic tool height section
how do i set the getregiser function in a M code header file
its this bit
A brief run through: As before the first step in the script is getting and defining necessary variables and the current state of the machine. Register values are retrieved using the GetRegister() function created in section 4.3. It is not defined in this script so it must be defined in an M code header file or a loaded module to allow access to it.
I think I have everything else working
Re: need some lua help
« Reply #1 on: May 02, 2015, 08:12:01 AM »
You may have to copy/paste the GetRegister() function from the header file and put it directly into your script.
At least in the scripter, when debugging, it errors out and will not "find" that function in the header file.
It MAY work if calling from the MDI, but, I have not tested that.
Offline dude1
  •  1,253 1,253
« Reply #2 on: May 02, 2015, 03:45:50 PM »
ok I tryed adding this it did not work
function GetRegister(regname)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname))
return mc.mcRegGetValueString(hreg)
end
is there a way of defining it as a macro
-- Auto Tool Setting Macro
 Requires the following instance registers to be defined
 TS_XPos-----------X position of probe (machine position)
 TS_YPos-----------Y position of probe (machine position)
 TS_Type-----------Offset type (1 or 2)
 TS_TouchPos-------Z position of touch off surface (machine position)
 TS_ProbeH---------Height of probe above touch off surface
 TS_DefaultL-------Default tool length guess
 TS_Retract--------Retract distance after probe touch
 Offset Type 1-----Length of tool from gauge line to tip
 Offset Type 2-----Distance from tip of tool to the touch position
--The function GetRegister() must be defined for use by macros  (its this bit I cant work out how to do)
« Last Edit: May 02, 2015, 03:54:04 PM by daniellyall »
« Reply #3 on: May 02, 2015, 07:44:08 PM »
Just in case you did not, you have to have the register defined, before you call it.........
Scott
Offline dude1
  •  1,253 1,253
« Reply #4 on: May 02, 2015, 08:22:34 PM »
thats the bit I dont now how to do
Offline dude1
  •  1,253 1,253
« Reply #5 on: May 02, 2015, 08:24:05 PM »
at a guess
function GetRegister(TS_XPos)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s",TS_XPos ))
end
« Reply #6 on: May 02, 2015, 09:09:07 PM »
I don't know if you can define them through statements but you can define them by opening up Regfile and adding them.  That's how I'm doing it.
Peter
Offline dude1
  •  1,253 1,253
« Reply #7 on: May 02, 2015, 10:59:54 PM »
not quite sure how to do that ever
Offline dude1
  •  1,253 1,253
« Reply #8 on: May 03, 2015, 12:36:41 AM »
I tried adding them to regfile it did not work
I think I have to do what`s at the bottom of page 16 top of 17 in the scripting manual
« Reply #9 on: May 03, 2015, 07:58:06 AM »
you have to pass: TS_XPos, as a string: "TS_XPos"
Scott
