Hello Guest it is November 22, 2026, 02:04:18 PM
Author Topic: need some lua help  (Read 33906 times)
Offline dude1
  •  1,253 1,253
Re: need some lua help
« Reply #20 on: May 06, 2015, 11:17:20 PM »
do i need to put in a address for this
unction m1005()
   --local macroname = "m1005"
   function GetRegister(regname)
      local rc;
      local inst = mc.mcGetInstance();
      local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname));
      return mc.mcRegGetValueString(hreg);
   end
   local TS_XPosVal = tostring(GetRegister("TS_XPos"));
   local YPosVal = tostring(GetRegister("TS_YPos"));
   local TypeVal = tostring(GetRegister("TS_Type"));
   local TouchPosVal = tostring(GetRegister("TS_TouchPos"));
   local ProbeHVal = tostring(GetRegister("TS_ProbeH"));
   local RetractLVal = tostring(GetRegister("TS_RetractL"));
   local DefaultVal = tostring(GetRegister("TS_DefaultL"));
   --regval = GetRegister("TS_Type");
   --wx.wxMessageBox(regval);
end
    m1005();
end
so the tool height probing macro can find it what is m1005 from the manual
Offline dude1
  •  1,253 1,253
« Reply #21 on: May 07, 2015, 02:54:38 AM »
I have played some more I add this into the Auto Tool Setting Macro from the manual
      local rc;
   end
now the Get touch off parameters work but when it gets to the Check Probe part it fails it comes up with this
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:48: wxLua: Expected a 'number' for parameter 2, but got a 'nil'.
Function called: 'mcSignalGetHandle(number, nil)'
01. mcSignalGetHandle(number, number, lightuserdata)
stack traceback:
   [C]: in function 'mcSignalGetHandle'
   [string "C:\Mach4Hobby\Macros\m1005.mcs"]:48: in function 'm1005'
   [string "C:\Mach4Hobby\Macros\m1005.mcs"]:109: in main chunk
I am running it in sim I have defind a probe input
« Reply #22 on: May 07, 2015, 06:45:49 AM »
Function called: 'mcSignalGetHandle(number, nil)'--is your error
the "nil" is the parameter 2, you need to have something like:   mc.ISIG_INPUT1 in there.
Scott
Offline dude1
  •  1,253 1,253
« Reply #23 on: May 07, 2015, 02:27:25 PM »
I think they did this with bits missing so people will learn a thing or two more than just copy and past code to its correct spot it`s not fun but I know how it was for you and ya bro to do now.
thanks for the help scott
Offline dude1
  •  1,253 1,253
« Reply #24 on: May 08, 2015, 02:10:56 AM »
thank you very much Scott I I think i got it working your hints are very good now to the next one
« Last Edit: May 08, 2015, 02:12:27 AM by daniellyall »
