Hello Guest it is November 22, 2026, 02:04:19 PM
Author Topic: need some lua help  (Read 33907 times)
Re: need some lua help
« Reply #10 on: May 03, 2015, 09:48:43 AM »
Sorry, I thought you said they weren't defined yet.  Once they are, you can follow the instructions to access them as you say.
Peter
Offline dude1
  •  1,253 1,253
« Reply #11 on: May 03, 2015, 02:45:20 PM »
I can find them its just the code needs them available for m code I worked out how to do it for one not all of them to together
Offline dude1
  •  1,253 1,253
« Reply #12 on: May 03, 2015, 09:11:51 PM »
this is what i have come up with probley wrong
Code: [Select]
function VariableParamFunc(...)
local TS_XPos = 0; local TS_YPos = 0; local TS_Type = 0; local TS_TouchPos = 0; local mInst = 0;
    local inst = mc.mcGetInstance(mInst);
TS_XPos, TS_YPos, TS_Type, TS_TouchPos = select(1, ...);
    if TS_XPos == nil then TS_XPos = "nil"; end
    if TS_YPos == nil then TS_YPos = "nil"; end
    if TS_Type == nil then TS_Type = "nil"; end
    if TS_TouchPos == nil then TS_TouchPos = "nil"; end
mc.mcCntlSetLastError(  inst,
                            " TS_XPos = " .. tostring( TS_XPos)..
                            " TS_YPos = ".. tostring(TS_YPos)..
                            " TS_Type = ".. tostring(TS_Type)..
                            " TS_TouchPos = ".. tostring(TS_TouchPos));
end
    VariableParamFunc();
    VariableParamFunc(2,3,4);
end
--You can pass as many params as you want, by putting in the function
--variables that get them via the order them come in at.
--this example handles three.
--Scott
Offline dude1
  •  1,253 1,253
« Reply #13 on: May 04, 2015, 06:42:54 AM »
right this lua is a pita
what I think I need to do is use this
function GetRegister(regname)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname))
return mc.mcRegGetValueString(hreg)
end
and have it like this
function GetRegister(TS_XPos)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s, TS_XPos",10))
end
function GetRegister(TS_YPos)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s, TS_Pos",10))
so on
then end with this
end
it compiles and runs and debugs with no problem
then at top of m1005 put in path to it or not
but when I run m1005 it compiles but does not run as it cant find the Register`s
I have put them in as iregs and gregs that did fa I could find and read them using one of Scott examples this one Quicky Wizard and/or Macro variable value viewer function.
the thing I am getting stuck on is m1005 finding them I meant to put them in a use macro or module.
with what I have put in here how wrong am I
also Scott is there something you or ya bro have posted that is the correct way of doing just pointers please, if I can`t work this out by the end of the week I might ask for the answer
for the time being I will just use the macro b to do tool height probing it works but I would rather use the code in the manual it`s a bit safer
and i will be doing the first cut with M4 Friday or monday just got to fix a bobo
« Reply #14 on: May 04, 2015, 06:47:49 AM »
You may have already done this but,
In the Register plugin, in the "instance" tab, that is where you add your register name and the value of that register.
i.e.
you will have under the "Name" and "Initial Value" columb:
TS_XPos             2.0
TS_YPos             1.5
etc....
Then in your code that you getting those values:
end
local TS_XPosVal = tonumber(GetRegister("TS_XPos"));
local TS_YPosVal = tonumber(GetRegister("TS_YPos"));
etc.
Scott
Offline dude1
  •  1,253 1,253
« Reply #15 on: May 04, 2015, 07:01:04 AM »
thank`s scott my brains burt for to day I will get back to it tommrow I have done half of that i have put the registers in
then i will do what you have suggested.
« Last Edit: May 04, 2015, 07:03:20 AM by daniellyall »
« Reply #16 on: May 04, 2015, 09:09:34 AM »
I always wondered what is the difference between global registers and instance registers, when to use one or the other, etc ;  i guess most programmers know about that , but is there a simple explanation somewhere for regular users ?
Offline dude1
  •  1,253 1,253
« Reply #17 on: May 06, 2015, 04:30:44 AM »
this is what I have so far its still not working
local macroname = "m1005"
local rc
end
local TS_XPosVal = tostring(GetRegister("TS_XPos"));
local YPosVal = tostring(GetRegister("TS_YPos"));
local TypeVal = tostring(GetRegister("TS_Type"));
local TouchPosVal = tostring(GetRegister("TS_TouchPos"));
local ProbeHVal = tostring(GetRegister("TS_ProbeH"));
local RetractLVal = tostring(GetRegister("TS_RetractL"));
local DefaultVal = tostring(GetRegister("TS_DefaultL"));
--regval = GetRegister("TS_Type")
--wx.wxMessageBox(regval)
    GetRegister ();
end
I have put them in the Register and can call them using
I keep getting this
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:34: attempt to call global 'GetRegister' (a nil value)
stack traceback:
   [string "C:\Mach4Hobby\Macros\m1005.mcs"]:34: in function 'm1005'
   [string "C:\Mach4Hobby\Macros\m1005.mcs"]:103: in main chunk
mcLua ERROR: Lua: Error while running chunk
« Reply #18 on: May 06, 2015, 07:45:53 AM »
Try this instead:
function m1005()
   --local macroname = "m1005"
      local rc;
      local inst = mc.mcGetInstance();
      local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname));
      return mc.mcRegGetValueString(hreg);
   end
   --regval = GetRegister("TS_Type");
   --wx.wxMessageBox(regval);
end
    m1005();
end
Offline dude1
  •  1,253 1,253
« Reply #19 on: May 06, 2015, 02:47:15 PM »
I should of been more correct I get this with the m1005 tool height probing from the scripting manual
I keep getting this
stack traceback:
having the reg in reg or the macro I can call them but the tool height probing macro cant find them
