Hello Guest it is November 22, 2026, 07:15:17 AM
Author Topic: Brain play.....  (Read 12053 times)
Brain play.....
« on: April 10, 2015, 08:08:42 AM »
Hi all
Just started to have a look at the brain function and have a question. Mainly I can't find cycle start command in the brain editor list.
I want to have cycle start trigger output 1 and  stop (not estop) turn it off again.
At the moment I have a start in m code but if I hit stop,  it stops motor on output 1 but won't restart when I hit cycle start again.
I thought if I use the brain I could trigger output 1 from start cycle and stop buttons.
Once this is sorted id like to add a remote start stop button via inputs.
Appreciate any help on this.
Thanks Dave
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Brain play.....
« Reply #1 on: April 11, 2015, 04:22:26 AM »
You'd be far better off using a screen editor and putting the code straight into the buttons
Re: Brain play.....
« Reply #2 on: April 11, 2015, 06:10:13 AM »
Can you monitor LED 904 and have it trigger the output?
Re: Brain play.....
« Reply #3 on: April 11, 2015, 07:52:12 AM »
Thanks guys
Couldn't find LED 904.
Also had a look at the screen editor program but couldn't see how to change command.
O we'll, I'll keep playing.
Re: Brain play.....
« Reply #4 on: April 11, 2015, 08:05:27 AM »
Sorry, it's 804
LED 804 is the Run LED.
Create a brain to activate Output 1 whenever LED 804 is on. It should do exactly what you want to do.
« Last Edit: April 11, 2015, 08:06:59 AM by ger21 »
Re: Brain play.....
« Reply #5 on: April 12, 2015, 07:05:36 AM »
Found the led 804, so what command do I tell it to do? I tried getting to trigger at >0 but that didn't do it.....
Re: Brain play.....
« Reply #6 on: April 13, 2015, 01:18:38 PM »
No Operation Pass Signal would most likely be what you want.
