Mach Discussion => General Mach Discussion => Topic started by: 4lowie on April 10, 2015, 09:08:42 AM
Hi all
Just started to have a look at the brain function and have a question. Mainly I can't find cycle start command in the brain editor list.
I want to have cycle start trigger output 1 and stop (not estop) turn it off again.
At the moment I have a start in m code but if I hit stop, it stops motor on output 1 but won't restart when I hit cycle start again.
I thought if I use the brain I could trigger output 1 from start cycle and stop buttons.
Once this is sorted id like to add a remote start stop button via inputs.
Appreciate any help on this.
Thanks Dave
You'd be far better off using a screen editor and putting the code straight into the buttons
Can you monitor LED 904 and have it trigger the output?
Thanks guys
Couldn't find LED 904.
Also had a look at the screen editor program but couldn't see how to change command.
O we'll, I'll keep playing.
Sorry, it's 804
LED 804 is the Run LED.
Create a brain to activate Output 1 whenever LED 804 is on. It should do exactly what you want to do.
Found the led 804, so what command do I tell it to do? I tried getting to trigger at >0 but that didn't do it.....
No Operation Pass Signal would most likely be what you want.
