Hello Guest it is October 24, 2026, 11:41:19 AM
Author Topic: CNC Wrapper Arcs problem  (Read 19142 times)
« on: March 18, 2015, 02:22:24 AM »
Hi All
I hope you can help.
I am tying to use CNC Wrapper to wrap text. I create the text in CamBam and then open it in wrapper and i get a message arcs found wrapper disabled .
How can I get around this problem.
thanks
Bob
Re: CNC Wrapper Arcs problem
« Reply #1 on: March 18, 2015, 05:41:29 AM »
From the manual .........
Russ
« Reply #2 on: March 18, 2015, 05:47:13 AM »
and ... same manual.
« Reply #3 on: March 19, 2015, 01:27:10 AM »
Hi Russ
Thanks for the reply.
Do you have a link to the full manual I dont seemto be able to find one.
Bob
  •  9,374 9,374
« Reply #4 on: March 19, 2015, 02:32:55 AM »
Hi Bob,
I know it does not address your original question but you may want to take a look at Terry's wrapper wizard http://www.machsupport.com/forum/index.php/topic,23216.0.html
It does not have any problems with arcs, it's free and is just so simple to use.  ;)
« Reply #5 on: March 19, 2015, 06:57:27 AM »
Hi Russ
Do you have a link to the full manual ...............
Bob
Go to where it was installed.
By default, mine was C,  Program Files, CNCWrapper.
You should see the HELP file there.
Russ
« Reply #6 on: March 20, 2015, 01:38:15 AM »
Thanks Russ
And Tweakie
Bob
« Reply #7 on: March 20, 2015, 07:37:31 AM »
Hi Bob,
Hi Tweakie ... and Terry (if you're listening),
I tried the TP Wrapper wizard but it doesn't seem to work for me (in sim).
I put the .set in a folder, then put that folder in Addons.
Wiz opens normally, enter info, returns to Mach, no wrappy.
Just Y moves, not A.
Where did I go wrong ?
Russ
  •  9,374 9,374
« Reply #8 on: March 20, 2015, 07:49:43 AM »
Hi Russ, I have no idea but I am sure Terry will know.
(I incorporated the wizard into my 1024.set and it works just fine here).
« Reply #9 on: March 20, 2015, 10:12:21 AM »
HIYA RUSS, DIDN'T Ya read the manual ??
Joking aside in SIM it will all look like you have Changed nothing.  The Magic is in using the Y to drive the A. That way you have use of arcs which makes a very smooth function for A. The toolpath Screen will show it as a FLAT projection in XY BUT it will MACHINE around the A when used
DO you have a 4th axis setup and running ? And it still does not work ??
