Hello Guest it is November 13, 2026, 01:11:02 PM
Author Topic: ajusting Z while cutting with xbox controller  (Read 9508 times)
« on: March 08, 2015, 09:03:24 PM »
Is there any possible way to adjust the Z while cutting? I have an oxy fuel setup and I have set the THC up and down to emulate on the keyboard, and it works, but just wondered if it was at all possible to have the xbox controller do it?
Re: ajusting Z while cutting with xbox controller
« Reply #1 on: March 09, 2015, 12:00:39 AM »
Can you assign hotkeys in the Xbox ??? If so then pick the SAME hotkeys that you work the THC up<>down with.
« Reply #2 on: March 09, 2015, 09:05:34 AM »
Thats exactly what I was hoping I could do. There are no choices in the drop down menus though. And I'm not sure where else to look.
was hoping someone on here had figured it out.
« Reply #3 on: March 09, 2015, 01:18:30 PM »
I would check the config for the plugin. That is where you maybe able to setup a hotkey.
