Hello
Guest
it is
November 13, 2026, 12:52:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
ajusting Z while cutting with xbox controller
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ajusting Z while cutting with xbox controller (Read 9504 times)
f_armer
2
on:
March 08, 2015, 09:03:24 PM »
Is there any possible way to adjust the Z while cutting? I have an oxy fuel setup and I have set the THC up and down to emulate on the keyboard, and it works, but just wondered if it was at all possible to have the xbox controller do it?
Logged
BR549
6,965
Re: ajusting Z while cutting with xbox controller
Reply #1 on:
March 09, 2015, 12:00:39 AM »
Can you assign hotkeys in the Xbox
If so then pick the SAME hotkeys that you work the THC up<>down with.
Logged
f_armer
2
Reply #2 on:
March 09, 2015, 09:05:34 AM »
Thats exactly what I was hoping I could do. There are no choices in the drop down menus though. And I'm not sure where else to look.
was hoping someone on here had figured it out.
Logged
BR549
6,965
Reply #3 on:
March 09, 2015, 01:18:30 PM »
I would check the config for the plugin. That is where you maybe able to setup a hotkey.
Logged
Print
Pages:
1
Go Up
« previous
next »
