Hello Guest it is October 12, 2026, 03:21:34 AM
Author Topic: X-axis reverse not working  (Read 56072 times)
« on: March 05, 2015, 01:11:30 PM »
I am using Mach4 latest build (2255 I think), but have also tried this on 2238.
I want to change the rotational direction of my X-axis stepper so when I use the -X job it moves left and +X jog it moves right. I selected Reverse? in the Mach->Configuration->Motor, but the motor does not reverse it's operation. To be clear, when I use the +X and -X jog commands, it does move both ways, but I want to reverse the operation of those commands.
Is this a software bug, or I am I not using it properly?
If I cannot overcome this in Mach4, could I rewire the stepper motor to reverse it's direction?
Re: X-axis reverse not working
« Reply #1 on: March 05, 2015, 01:20:50 PM »
Yes, you can reverse the direction of all motion of a stepper by swapping the
two wires of ONE coil of the motor.
That said, the software problem does need to be addressed. What plug-in
are you using?
Steve Stallings
www.PMDX.com
« Reply #2 on: March 06, 2015, 04:52:30 PM »
I am using Mach4 2255 with the ESS and plugin.
Reversing the wires may be the easiest solution for now as many things seem not to work with Mach4 and ESS.
« Reply #3 on: March 09, 2015, 01:40:34 AM »
I had the same issue. Discovered that if you change this setting you must restart MACH4 for it to have effect. Think I remember hearing that in a tutorial video somewhere as well.
Now I restart whenever I make a config change.
« Reply #4 on: April 08, 2015, 05:21:18 PM »
I am having the same problem with Mach4 and the ESS. I've checked the Reverse box and restarted the program. The box is still checked but the motors aren't reversed.
So I am going to do what Steve said and swap one coil of the steppers. So I don't screw something up, do I just swap either the A or B phase, as shown in the pinout pic attached?
« Reply #5 on: April 08, 2015, 05:26:12 PM »
If you swap "Phase B" with "Phase /B" that should do the trick.
Only swap the wires to one coil of the motor.
Steve
Steve Stallings
www.PMDX.com
« Reply #6 on: April 08, 2015, 05:45:16 PM »
Thanks Steve.
Offline Bronk
  •  12 12
« Reply #7 on: April 11, 2015, 06:47:37 AM »
I had the same problem. No amount of saving and restarting would reverse the motor directions.  Just swap the leads on one of your motor phases as others have said.
« Reply #8 on: May 17, 2015, 01:30:10 AM »
Running 4.0.1.2441, with ESS plugin 1.0.1.130 - same problem, same tests.
Will try reversing a coil.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #9 on: May 17, 2015, 02:03:04 AM »
where are you trying to reverse the motor, if you are using the ess then all reversing of the motors needs to be done within the plugin config-inputs by making a motor dir input active high or active low.
DazTheGas
