Hello Guest it is November 13, 2026, 12:22:39 PM
Author Topic: Mach3 and Dropbox  (Read 10607 times)
Mach3 and Dropbox
« on: February 27, 2015, 05:07:40 PM »
I want to store all my machining files on dropbox and then load them straight into mach3 from there. but it would seem mach3 doesn't work with dropbox
is there a way to get mach3 to work with dropbox?
Re: Mach3 and Dropbox
« Reply #1 on: February 27, 2015, 11:36:04 PM »
If you don't want to have any problems, then you should only run g-code files from the local hard drive. Even running them from a flash drive can cause problems.
« Reply #2 on: February 28, 2015, 05:16:12 AM »
really?
I always run from a memory stick, never had a problem
« Reply #3 on: February 28, 2015, 06:49:40 AM »
Many people do have problems doing that. It's a known issue.
