Hello
Guest
it is
November 13, 2026, 11:04:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 and Dropbox
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 and Dropbox (Read 10603 times)
andy_con
123
Mach3 and Dropbox
on:
February 27, 2015, 05:07:40 PM »
I want to store all my machining files on dropbox and then load them straight into mach3 from there. but it would seem mach3 doesn't work with dropbox
is there a way to get mach3 to work with dropbox?
Logged
ger21
6,295
Re: Mach3 and Dropbox
Reply #1 on:
February 27, 2015, 11:36:04 PM »
If you don't want to have any problems, then you should only run g-code files from the local hard drive. Even running them from a flash drive can cause problems.
Logged
andy_con
123
Reply #2 on:
February 28, 2015, 05:16:12 AM »
really?
I always run from a memory stick, never had a problem
Logged
ger21
6,295
Reply #3 on:
February 28, 2015, 06:49:40 AM »
Many people do have problems doing that. It's a known issue.
Logged
Print
Pages:
1
Go Up
« previous
next »
