Hello Guest it is October 21, 2026, 02:25:58 AM
Author Topic: BOBCAD MACH3 post  (Read 23987 times)
BOBCAD MACH3 post
« on: April 11, 2007, 03:59:44 PM »
Could somebody please load this code in there mach3 and see if there getting a bunch of loop de loos  circles see if im crazy.
when i  create the code in Sheetcam everything is fine .    when i take the same drawing and make some code with bobcad i get a bunch of  circles that mach will cut just wondering if it is operator error or my post is screwed up. because if i generate some code with the bobcad plasma post the circles are not there but this is for my mill
Thanks John
i think i put this in the wrong catagory im  terribly sorry probably should have been in third party software
« Last Edit: April 11, 2007, 04:05:01 PM by dgalaxy »
Re: BOBCAD MACH3 post
« Reply #1 on: April 11, 2007, 06:06:04 PM »
Try setting the IJ mode to the opposite of what it is now, you will find it on the General Config page.
« Reply #2 on: April 11, 2007, 06:35:49 PM »
Ya Hood i tried that and all that does is give me a whole bunch of circles  does it show 4 little circles on your computer
« Reply #3 on: April 11, 2007, 06:38:34 PM »
what does that mean if most of the code is blue and the 4 little circles are purple thats the way it is showing up on mine
« Reply #4 on: April 11, 2007, 07:41:15 PM »
This is what I get. The reason for the differnet colors is just another good feature of Mach. Do these help?
« Reply #5 on: April 11, 2007, 07:47:30 PM »
ya thats right do you see those circles like on the bottom of his chest and his feet and legs" these arent supposed to be there". well i must not be crazy. Mach is following this.  when i build the code in sheetcam it does not make those circles. so am i right it must be the bobcad post  if i use the bobcad plasma post it doesnt make those circles either what do ya think? Chaoticone
John
« Last Edit: April 11, 2007, 07:52:32 PM by dgalaxy »
« Reply #6 on: April 11, 2007, 07:51:28 PM »
I think it must be in the post processor. When you generate the code do you have an option of doing arc leadins?
« Reply #7 on: April 11, 2007, 07:59:33 PM »
 This for my mill i cant see anything ive opened everybox  and  if i switch to plasma post instead of mill there are no circles.  i geuss ill have to call them. Thanks Brett so much  for looking at this for me!!!!!   I appreciate it a whole bunch you have no idea.
John
« Reply #8 on: April 11, 2007, 08:10:35 PM »
Your welcome John, I wish I could do more.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #9 on: April 12, 2007, 02:32:44 AM »
In the BOBCAD nc code viewer on the menu setup is Driver setup, on the general tab try changing the MAX CIRCULAR MOVEMENT options and re-generate the code.
Also turn off the XY show only changed options.
I think its got something to do with the G02's not having X and Y figures.
Graham.
« Last Edit: April 12, 2007, 02:50:14 AM by Graham Waterworth »
