Hello Guest it is November 13, 2026, 10:02:02 AM
Author Topic: Vfd settings  (Read 21091 times)
Vfd settings
« on: February 23, 2015, 04:20:29 PM »
Hey guys having a problem with my vfd. its a huanyang 110 volt 1.5 kw inverter. I know its chinese junk but its what i got.  my problem is that its oinly spinning at 11520 rpms as per the read out.  I found a couple posts about setting and changed my settings in the vfd but then it would not turn on.   Reset settings to what they were and is working again.  Has anyone seen this before.  Thanks for your help
Re: Vfd settings
« Reply #1 on: February 23, 2015, 08:25:40 PM »
Are you using the VFD front panel controls or Mach 3 for speed control? Make sure the max speed in the VFD is set for 24000 and the drive is setup and wired for 110V and not 220V. Sounds like it's running at 1/2 speed.
Re: Vfd settings
« Reply #2 on: February 23, 2015, 08:39:37 PM »
Also make sure the Hz is set correct for the motor and RPM.
Just a thought,(;-)TP
Re: Vfd settings
« Reply #3 on: February 24, 2015, 12:46:25 PM »
Im using the panel on the vfd.  I dont have the spindle control set up on mach3 yet. Its set to 110volt Im sure of that> i dont know what pd code to use to change the max rpm setting.
Re: Vfd settings
« Reply #4 on: February 24, 2015, 01:26:24 PM »
So, you don't have the manual ? ? or parameter list ? ?
Re: Vfd settings
« Reply #5 on: February 24, 2015, 02:01:15 PM »
I do have the manual but i cant understand it.  i changed the rated motor revolution to 24000 rpm and it reads 19200 now but i dont think its going that fast. It could be though
Re: Vfd settings
« Reply #6 on: February 24, 2015, 05:15:54 PM »
Is it paper ? or a PDF that you could attach ? or can you find it on-line and post a link ?
Someone around here just might be able to decipher it fer ya.
Russ
Re: Vfd settings
« Reply #7 on: February 25, 2015, 10:56:34 AM »
Its a paper manual and its in English. Im just new to this stuff and dont really understand what Im reading.
Re: Vfd settings
« Reply #8 on: February 25, 2015, 11:56:58 AM »
what is the model number on it? and how are you checking the RPM.... with a tachometer or from the vfd readout?
Re: Vfd settings
« Reply #9 on: February 25, 2015, 01:34:22 PM »
model number is hy01d511b.  Im reading rpm from vfd screen.  The vfd is working good enough for what im trying to do I just want it set up correctly so it works the best that it can and i dont burn the vfd or spindle out.  i want to set it up through mach 3 for sturning it on and off eventually. I have it mounted on the ceiling in my garage and i have to hit the run and stop button everytime i want to use the router haha
