Hello Guest it is November 13, 2026, 03:01:40 PM
Author Topic: Vfd settings  (Read 21102 times)
Re: Vfd settings
« Reply #10 on: February 25, 2015, 03:02:50 PM »
Set in the following order: PD005=400, PD004=400, PD003=400, PD144=3000
People should not buy VFD's if they don't understand how to set up and properly wire them. They are not plug and play devices. Huanyang drive are very low quality junk that don't (can't) meet UL or CE certification. They all lack RF suppression which makes them interfere with stepper electronics. You can buy a 1.5kw, 110V VFD's directly from Huanyang for $100. Most never run past a couple of months before self destructing.  Another trick 3rd party Chinese sellers do remove the drive data name plate and sell 1.5kw drives as 2.2kw units and prices. Good luck trying to get a replacement for a blown up drive.
Re: Vfd settings
« Reply #11 on: February 25, 2015, 05:21:24 PM »
well its all i have right now. Ill try to buy better stuff next time i try and learn stuff..
Re: Vfd settings
« Reply #12 on: February 25, 2015, 05:21:45 PM »
thanks for the specs though
