Hello Guest it is November 13, 2026, 11:03:10 AM
Author Topic: plot not showing  (Read 32775 times)
plot not showing
« on: February 23, 2015, 01:26:10 PM »
i'm running mach3 R3.043.066 and can't get the plot to show on EITHER computer.
when it was before(i changed nothing). i tried different versions to the same effect. shows the table
but no trace whatsoever.
Thanks for any help !
Kenneth
Re: plot not showing
« Reply #1 on: February 23, 2015, 03:44:35 PM »
Is the code fully loading?
Have you got the toolpath turned off? button for that on the Diagnostics page, just above the Reset button.
« Reply #2 on: February 24, 2015, 04:52:10 AM »
yes, it's a simple code. clicking the on/off has no effect.
the code runs fine with no problem.
Thanks Hood !
Kenneth
« Reply #3 on: February 24, 2015, 05:04:29 AM »
Seems to load fine here, are you using a standard screenset or a custom one?
 Can you attach your xml and I will have a look.
« Reply #4 on: February 24, 2015, 05:12:34 AM »
this is from cnc4pc. (MR Arturo).
Kenneth
« Reply #5 on: February 24, 2015, 05:23:08 AM »
Ok you have a custom screenset, it could it that has the problem.
Try going to view menu then Load screens and then browse and choose 1024.set and see if that helps.
« Reply #6 on: February 24, 2015, 05:27:45 AM »
thanks. the plot shows as should. no way to use other set file ?
Kenneth
« Reply #7 on: February 24, 2015, 05:30:48 AM »
If you attach it I will have a look, it may just be wrongly configured for the toolpath.
« Reply #8 on: February 24, 2015, 05:45:55 AM »
trying to send but can't get pass sending a copy. still trying
Kenneth
« Reply #9 on: February 24, 2015, 05:48:39 AM »
don't know if this will get thru but..............
thanks for any help Hood. greatly appreciated !!!
Kenneth
