Hello
Guest
it is
November 13, 2026, 09:53:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
plot not showing
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: plot not showing (Read 32773 times)
Kenneth
279
plot not showing
on:
February 23, 2015, 01:26:10 PM »
i'm running mach3 R3.043.066 and can't get the plot to show on EITHER computer.
when it was before(i changed nothing). i tried different versions to the same effect. shows the table
but no trace whatsoever.
Thanks for any help !
Logged
Kenneth
Carnoustie, Scotland
Re: plot not showing
Reply #1 on:
February 23, 2015, 03:44:35 PM »
Is the code fully loading?
Have you got the toolpath turned off? button for that on the Diagnostics page, just above the Reset button.
Logged
Kenneth
279
Reply #2 on:
February 24, 2015, 04:52:10 AM »
yes, it's a simple code. clicking the on/off has no effect.
the code runs fine with no problem.
Thanks Hood !
Logged
Kenneth
Reply #3 on:
February 24, 2015, 05:04:29 AM »
Seems to load fine here, are you using a standard screenset or a custom one?
Can you attach your xml and I will have a look.
Logged
Kenneth
279
Reply #4 on:
February 24, 2015, 05:12:34 AM »
this is from cnc4pc. (MR Arturo).
Logged
Kenneth
Reply #5 on:
February 24, 2015, 05:23:08 AM »
Ok you have a custom screenset, it could it that has the problem.
Try going to view menu then Load screens and then browse and choose 1024.set and see if that helps.
Logged
Kenneth
279
Reply #6 on:
February 24, 2015, 05:27:45 AM »
thanks. the plot shows as should. no way to use other set file ?
Logged
Kenneth
Reply #7 on:
February 24, 2015, 05:30:48 AM »
If you attach it I will have a look, it may just be wrongly configured for the toolpath.
Logged
Kenneth
279
Reply #8 on:
February 24, 2015, 05:45:55 AM »
trying to send but can't get pass sending a copy. still trying
Logged
Kenneth
Kenneth
279
Reply #9 on:
February 24, 2015, 05:48:39 AM »
don't know if this will get thru but..............
thanks for any help Hood. greatly appreciated !!!
Logged
Kenneth
Print
Pages:
1
2
3
Go Up
« previous
next »
