Hello
Guest
it is
November 23, 2026, 11:14:12 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
DRO setting
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DRO setting (Read 12356 times)
studysession
176
DRO setting
on:
February 15, 2015, 09:57:05 AM »
Where do I click to make Mach3 keep the DRO settings? I shut mach3 and the DRO settings are not the same when I open. I usually have everything where I want zero or 1 inch offset from zer but when I open they seem to show some random set of numbers....
thanks
http://celticmachining.blogspot.com/
Overloaded
4,923
Re: DRO setting
Reply #1 on:
February 15, 2015, 11:40:34 AM »
Under Config./General Config., lower right, Persistent DRO's.
studysession
176
Re: DRO setting
Reply #2 on:
February 15, 2015, 01:02:53 PM »
Thank you
Had all these settings for a long time and now doing a fresh new setup and can't remember each one and not having luck on search
Overloaded
4,923
Re: DRO setting
Reply #3 on:
February 15, 2015, 03:57:24 PM »
You can always revert to the trusty ol' manual.
It's all in there at your immediate disposal.
Re: DRO setting
Reply #4 on:
February 15, 2015, 04:14:41 PM »
You can print or save to a file all your current mach3 settings in an easy readable format for record by using
MachProfile ( i use V2.09) available from K.Dietz site where you can also download MAchScreen, etc.
Print
Pages:
1
Go Up
« previous
next »
