Mach Discussion => General Mach Discussion => Topic started by: studysession on February 15, 2015, 10:57:05 AM
Where do I click to make Mach3 keep the DRO settings? I shut mach3 and the DRO settings are not the same when I open. I usually have everything where I want zero or 1 inch offset from zer but when I open they seem to show some random set of numbers....
thanks
Under Config./General Config., lower right, Persistent DRO's.
Thank you
Had all these settings for a long time and now doing a fresh new setup and can't remember each one and not having luck on search :)
You can always revert to the trusty ol' manual. :)
It's all in there at your immediate disposal.
You can print or save to a file all your current mach3 settings in an easy readable format for record by using
MachProfile ( i use V2.09) available from K.Dietz site where you can also download MAchScreen, etc.
