Hello Guest it is November 22, 2026, 10:03:22 PM
Author Topic: " no spindle feedback seen in G95 units/rev mode  (Read 10672 times)
« on: January 17, 2015, 10:17:33 AM »
" no spindle feedback seen in G95 units/rev mode "
Hello Chaps
what is the cure for the above error message??
Is there a published list of error codes that I can access ?
regards
fred
Re: " no spindle feedback seen in G95 units/rev mode
« Reply #1 on: January 18, 2015, 01:49:16 AM »
Do you have an index pulse from the spindle to Mach?
If not then that is why you get that message as it is looking for it and not seeing it so does not know if the rpm is as commanded.
« Reply #2 on: January 18, 2015, 09:06:09 AM »
thanks hood- i will check
