Hello Guest it is November 20, 2026, 01:52:28 AM
Author Topic: Wrong working with Mach3.  (Read 13849 times)
« on: April 05, 2007, 06:12:11 PM »
Hello to all. As it is looked at frm the images, the circuit made with Mach3 is not correct and with greater circuits the errors increase. I enclose also the working file. Thanks in advance. Giordano
« Last Edit: April 05, 2007, 06:18:10 PM by giordano »
Re: Wrong working with Mach3.
« Reply #1 on: April 06, 2007, 01:04:41 PM »
It looks to me like you have lost steps... try sherline mode and see if you have the same problem
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: April 06, 2007, 03:13:54 PM »
Hi Brian. The strange thing is that some holes are to the center and others no. The axle are planned to 10 mm / s and the acceleration to 50 mm / sec*sec. The motors are planned to 800 step for turn. Thanks. Giordano
« Reply #3 on: April 06, 2007, 04:01:42 PM »
Also after you are done the run move back to X0.0 Y0.0 and see if you are on position
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: April 06, 2007, 11:06:35 PM »
Hi, Giordano
Your F speeds are set to F300, Have you try-ed slowing  it down.
When you setup Mach3 your Max Velocity and acceleration settings are based on F100, I think, I May be wrong about that ?.
Is your Mach Job finishing faster than the other. ?
All the holes seem to be in the center on Pre-cut view. ?
Just some Thought's  Hear, Chip
« Last Edit: April 06, 2007, 11:08:27 PM by afn09556 »
« Reply #5 on: April 07, 2007, 02:09:39 AM »
Hi. In the preview the holes are to the center. I will try to reduce the speed.
The format of export of the post processor is important?
This line in the format 0.00: N4s G00 X14.84 Y14.71
The same line in the format 0.0000: N4 G00 X14.8361 Y14.7066. Thanks. Giordano
