Hello Guest it is October 20, 2026, 04:47:07 PM
Author Topic: PHOTOvCARVE problems!!  (Read 168123 times)
Re: PHOTOvCARVE problems!!
« Reply #40 on: December 21, 2014, 03:53:34 PM »
The thing I see in the VID compared to the Gcode is the Z axis direction may be backwards.
From the MDI line type
G91 {enter}
G1 Z1 F10 {enter}
DID the Z move UP or DOWN ???  It should have moved UP.
Just a thought, (;-) TP
« Reply #41 on: December 21, 2014, 04:03:18 PM »
well it has moved as it should for a few months.
Then this last week it decided that when you tell it to cut a pocket ot do a PVC project it wanted to plunge into the wood and drag across the material leaving a trough and then come up a bit and cut the edges like they should be.  Then the whole thing went to hell doing what ever it wanted.
Now I am back to just plunging and that is about all I can get because I don't want it cutting any holes in my work table, bench...floor...yard...
« Reply #42 on: December 21, 2014, 04:18:19 PM »
please try this simple exercise
G91 {enter}
G1 Z1 F10 {enter}
Offline dude1
  •  1,253 1,253
« Reply #43 on: December 21, 2014, 04:26:38 PM »
they do its a ESS http://warp9td.com/index.php/order   that's just one of them that can connect up with a G540
there are other ones available ever Ethernet or usb
« Reply #44 on: December 21, 2014, 04:28:41 PM »
I tried what you said.  The head went down
Offline rdean
  •  94 94
« Reply #45 on: December 21, 2014, 04:50:10 PM »
BR549 will comment this when he sees it.
If you started at "0" then the z axis should move up 1" as the code shows
Ray
« Last Edit: December 21, 2014, 04:51:53 PM by rdean »
« Reply #46 on: December 21, 2014, 04:52:46 PM »
Ray
Is that up from machine coord or the zero I set?
« Reply #47 on: December 21, 2014, 07:14:02 PM »
IF you did the exercise as I suggested the head should move UP reguardless of anything else.
You would have set Mach3 to incremental movement(G91) and then MOVED in a positive Z  direction (UP).
IF it went down then there is your problem.
(;-)TP
« Reply #48 on: December 21, 2014, 07:41:25 PM »
then I have to ask...how could it changes it's own direction after working for weeks and weeks properly?
« Reply #49 on: December 21, 2014, 07:49:54 PM »
And why wont it hold calibration?
