Hello Guest it is November 13, 2026, 09:46:46 AM
Author Topic: Torch mate cutting tables what breakout board is used?  (Read 8633 times)
« on: December 12, 2014, 03:32:39 PM »
Torchchmate is run over a parallel port will another breakout board work with their software?
Re: Torch mate cutting tables what breakout board is used?
« Reply #1 on: December 12, 2014, 04:10:22 PM »
Torchmate is run with either a serial port OR a USB port. There is not a plugin that I know of that will work with the Torchmate controller.
The torchmate runs with a FLASHCUT control system and it uses a self contained Z axis that is seperate from the controller so it will NOT integrate with Mach3 easily.
Next question is WHY would you want to change (;-).
« Last Edit: December 12, 2014, 04:21:27 PM by BR549 »
« Reply #2 on: December 12, 2014, 08:15:49 PM »
I'm doing a service call on a guys machine. It hasn't run in 6 years
I was just curious if it used a common breakout board.
