Hello Guest it is November 22, 2026, 09:07:06 AM
Author Topic: USING INPUTS WITH WARP9 SMOOTH STEPPER  (Read 8261 times)
« on: October 17, 2014, 05:01:27 AM »
I need to add more inputs for limit switches. Mach 3, warp9 ss, windows xp, LAPTOP. I used the warp9 pinout addresses (port 3, pin 1-3, etc) in port and pins but I do not get any signal on the diagnostics page when operating the limit switch. Does mach 3 recognize port 3 or am I supposed to check something somewhere in mach 3 so it does.?  Whats the difference between single ended and differential inputs?
Re: USING INPUTS WITH WARP9 SMOOTH STEPPER
« Reply #1 on: October 25, 2014, 01:48:03 PM »
Mach will recognise Port3 no problem, possibly there is a setting in the plugin to configure pins 1-9 as inputs rather than outputs?
