Hello Guest it is November 13, 2026, 10:45:24 AM
Author Topic: Z height unstable  (Read 11329 times)
Z height unstable
« on: September 09, 2014, 01:47:33 PM »
Good day folks. When I set the Z either using AUTO ZERO button or manually, it doesn't seem to "remember" it. So many times I Have set the Z to zero then ran the code and it plunges into the work or sits and moves around in the air.
What gives?? Am I missing a setting or something??
MACH 3  Version R3.043.066  is what I am using.
I would love to fix this.
Andrew
Re: Z height unstable
« Reply #1 on: September 09, 2014, 05:13:11 PM »
1) Is your zero actually being set correctly?
2) Is there anything in your g-code that can alter Z zero? (G43?)
« Reply #2 on: September 10, 2014, 09:21:39 AM »
Well I use an auto zero script from this forum and sometimes when I set it manually it does the same thing. I'll look for a G43 code. I have Aspire that makes my G code.
Thank you Gerry.
Andrew
« Reply #3 on: September 10, 2014, 09:24:07 AM »
I think I found something.
N130 (V-Bit {60 deg 0.5"})
N140G00G43Z0.8000H1
that is some G code from the beginning of the file.  Is that what you meant about G43?? If so how do I stop it from doing that??
Andrew
« Reply #4 on: September 10, 2014, 09:37:58 AM »
Do you have a tool length for tool #1 in your tool table?
« Reply #5 on: September 12, 2014, 01:02:22 PM »
All my bits are tool 1 it would seem. I looked in the tool database but is there somewhere else?
