Mach Discussion => General Mach Discussion => Topic started by: antennas on September 09, 2014, 02:47:33 PM
Good day folks. When I set the Z either using AUTO ZERO button or manually, it doesn't seem to "remember" it. So many times I Have set the Z to zero then ran the code and it plunges into the work or sits and moves around in the air.
What gives?? Am I missing a setting or something??
MACH 3 Version R3.043.066 is what I am using.
I would love to fix this.
Andrew
1) Is your zero actually being set correctly?
2) Is there anything in your g-code that can alter Z zero? (G43?)
Well I use an auto zero script from this forum and sometimes when I set it manually it does the same thing. I'll look for a G43 code. I have Aspire that makes my G code.
Thank you Gerry.
Andrew
I think I found something.
N130 (V-Bit {60 deg 0.5"})
N140G00G43Z0.8000H1
that is some G code from the beginning of the file. Is that what you meant about G43?? If so how do I stop it from doing that??
Andrew
Do you have a tool length for tool #1 in your tool table?
All my bits are tool 1 it would seem. I looked in the tool database but is there somewhere else?
