Hello Guest it is November 23, 2026, 01:07:36 AM
Author Topic: Scaling  (Read 9693 times)
Scaling
« on: August 24, 2014, 10:07:23 AM »
Hello I am new to the forum.
I use my homemade CNC portal milling
I use Mach3 for control
My problem is that my x axis naturally jumps on scaling during the milling
she jumps from +10000 to -10000
and mills then everything mirrored
Is there anyone who can solve my problem
Thanx in advance
« Last Edit: August 24, 2014, 10:17:09 AM by Shadowmuis »
  •  9,378 9,378
Re: Scaling
« Reply #1 on: August 24, 2014, 11:12:51 AM »
Hi Shadowmuis,
You need to contact licence support http://www.machsupport.com/contact-us/ to check that the Mach3 license you are using is genuine.
Re: Scaling
« Reply #2 on: August 24, 2014, 11:41:20 AM »
Tweakie thanks for the quick response
I certainly do
got the program from a friend
guess he did not buy it
but cracked the program
  •  9,378 9,378
Re: Scaling
« Reply #3 on: August 24, 2014, 02:40:02 PM »
That may explain it then  ;)
