Mach Discussion => General Mach Discussion => Topic started by: Shadowmuis on August 24, 2014, 11:07:23 AM
Hello I am new to the forum.
I use my homemade CNC portal milling
I use Mach3 for control
My problem is that my x axis naturally jumps on scaling during the milling
she jumps from +10000 to -(http://)10000
and mills then everything mirrored
Is there anyone who can solve my problem
Thanx in advance
(http://)
Hi Shadowmuis,
You need to contact licence support http://www.machsupport.com/contact-us/ to check that the Mach3 license you are using is genuine.
Tweakie thanks for the quick response
I certainly do
got the program from a friend
guess he did not buy it
but cracked the program
That may explain it then ;)
