Hello Guest it is October 20, 2026, 03:26:42 AM
Author Topic: - fixture save...  (Read 21076 times)
- fixture save...
« on: August 14, 2014, 10:27:46 AM »
i'm using mach3 r3.043.066.
it never ask me to save fixture. i tried with the option "optional offset save"
checked and un-checked. i created a button(122) so i can save it but would like
to make a safety so it would ask when i close.
 Thanks !
Kenneth
Re: - fixture save...
« Reply #1 on: August 14, 2014, 10:37:28 AM »
Check Optional Offset Save.
Close and Restart Mach3.
Zero an axis. (that's not already zero)
Close Mach3.
You should see the message to save.
« Reply #2 on: August 14, 2014, 10:44:55 AM »
that didn't show the option to save.
it does show to end session.
« Last Edit: August 14, 2014, 10:53:30 AM by Kenneth »
Kenneth
« Reply #3 on: August 15, 2014, 05:44:57 PM »
Attach your xml and I will take a look and see if I can replicate your issue.
« Reply #4 on: August 18, 2014, 04:19:12 AM »
Thanks !
Kenneth
« Reply #5 on: August 18, 2014, 05:59:35 AM »
thanks again Hood !
Kenneth
« Reply #6 on: August 28, 2014, 09:59:49 AM »
still having the problem. what do i look for in the xml file ?
did i attach the correct file ? should i START from scratch
or is it also part of machscreen(1.60) ?
Thanks for any help !
Kenneth
« Reply #7 on: August 28, 2014, 11:10:42 AM »
i fixed it by deleting the xml file and reopening mach3 and then loading my set file.
it ask to save fixture but doesn't really save position. is there something else i can
do ?  Thanks !
Kenneth
« Reply #8 on: September 03, 2014, 10:04:16 AM »
am i asking REALLY dumb questions ?
BESIDES this one.
« Last Edit: September 03, 2014, 10:07:03 AM by Kenneth »
Kenneth
« Reply #9 on: September 04, 2014, 07:21:30 AM »
Please don't tell me i can't get help cause i don't like M4 ?
Kenneth
