Hello Guest it is November 22, 2026, 11:03:22 PM
Author Topic: Slaved Axis Moves Wrong Direction When Homing  (Read 8961 times)
« on: August 03, 2014, 09:48:21 PM »
A friend of mine just bought a CNC router, which has a slaved axis on the gantry.  All works perfectly when jogging, but when homing, the two slaved motors move opposite directions.  What settings can cause that?
Re: Slaved Axis Moves Wrong Direction When Homing
« Reply #1 on: August 04, 2014, 06:29:32 AM »
Home negative in Config>Homing. Make sure both are the same.
If they are the same, then one axis is backwards, and he needs to reverse it.
« Reply #2 on: August 04, 2014, 10:49:04 AM »
Gerry,
Thanks, I'll have him give that a try.
Regards
