Hello
Guest
it is
October 21, 2026, 03:49:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Fusion 360 and Mach 3 post error
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Fusion 360 and Mach 3 post error (Read 10281 times)
golash
81
on:
August 01, 2014, 10:41:01 PM »
Hi
I just generated my first code in Fusion 360. When I attempt to run the code I get this
error : Current point same as end point of arcLine 21. I was changing setting in the general
config section. I changed the Distance Mode and IJ mode hoping that a change would help
my error. Now I have no idea what those setting should be.
Need some help this is a bit over my head.
Logged
Tweakie.CNC
9,374
Super Kitty
Re: Fusion 360 and Mach 3 post error
Reply #1 on:
August 02, 2014, 02:14:52 AM »
Hi Golash,
Normally, Distance Mode would be set to Absolute and IJ Mode set to Incremental.
Did changing the IJ Mode to Absolute solve the problem with running your code ??
Logged
Print
Pages:
1
Go Up
« previous
next »
