Hello Guest it is November 22, 2026, 09:07:07 AM
Author Topic: Repetitive accuracy shift  (Read 9664 times)
« on: June 09, 2014, 07:46:13 AM »
I have my mill set up with steppers and everything seems to be moving smoothly with no steps missed. When I calibrate the steps per unit, and run four test runs in a row, in the same direction, after every two runs it changes .005" (example: .100, .100, .105, .105, .110, .110 etc). It is very repetitive in this pattern and is present in all three axes. Any thoughts?
Re: Repetitive accuracy shift
« Reply #1 on: June 09, 2014, 12:35:15 PM »
Please attach your xml.
Are the readings you mention true readings or Machs DRO readings?
« Reply #2 on: June 09, 2014, 09:00:53 PM »
Hi Hood,
It is the actual measurement, with a dial indicator. It is just very strange how repetitive the error is, yet only ever other test run. Thanks
« Reply #3 on: June 10, 2014, 02:34:32 AM »
Please attach your xml and I will see if I can find an issue in it.
