Hello Guest it is October 21, 2026, 06:27:23 AM
Author Topic: post processors difference?  (Read 44421 times)
« on: June 07, 2014, 04:25:25 AM »
RE: Post processors: whats the difference between Mach 2/3 ATC Arcs, Mach 2/3 Arcs and Mach 2/3 wrapx2a ?
Re: post processors difference?
« Reply #1 on: June 07, 2014, 05:01:58 AM »
Mach 2/3 Arcs, is what you would use for normal cutting jobs.
Mach 2/3 ATC Arcs, is for when your machine utilizes an Automatic Tool Changer. (ATC)
Mach 2/3 wrapx2a, is for rotary work where you are wrapping the X axis around your A axis.
This is dependant on how your rotary axis is set up. You may need to use Mach 2/3 wrapy2a instead.
« Reply #2 on: June 07, 2014, 06:40:27 AM »
If the job uses multiple tools, if you all the g-code for all tools in one file, you must use the ATC post. Even if you change tools manually.
The Mach2/3 Arcs post only allows one tool per file.
« Reply #3 on: June 07, 2014, 08:34:49 AM »
Thank you. Now I am just a little bit smarter. :)
« Reply #4 on: June 07, 2014, 08:37:45 AM »
Thank you for your input.  :)
« Reply #5 on: May 24, 2023, 04:14:43 AM »
Hi
what is the difference between mach3-4(mm) and mach3-4 arcs (mm)?
Offline ZASto
  •  434 434
« Reply #6 on: May 24, 2023, 04:47:35 AM »
arcs is generating G02/G03 where possible while the other one will generate a lot of straight line segments approximating arcs.
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #7 on: May 24, 2023, 04:50:19 AM »
thx alot,
i have artcam 2018 and mach3,,, so which is better to generate my G code as mach3 arcs(mm) or mach3 (mm)?
Offline ZASto
  •  434 434
« Reply #8 on: May 24, 2023, 10:03:32 AM »
mach3 arcs(mm)
