Mach Discussion => General Mach Discussion => Topic started by: GrandpawB on June 07, 2014, 05:25:25 AM
RE: Post processors: whats the difference between Mach 2/3 ATC Arcs, Mach 2/3 Arcs and Mach 2/3 wrapx2a ?
Mach 2/3 Arcs, is what you would use for normal cutting jobs.
Mach 2/3 ATC Arcs, is for when your machine utilizes an Automatic Tool Changer. (ATC)
Mach 2/3 wrapx2a, is for rotary work where you are wrapping the X axis around your A axis.
This is dependant on how your rotary axis is set up. You may need to use Mach 2/3 wrapy2a instead.
If the job uses multiple tools, if you all the g-code for all tools in one file, you must use the ATC post. Even if you change tools manually.
The Mach2/3 Arcs post only allows one tool per file.
Thank you. Now I am just a little bit smarter. :)
Thank you for your input. :)
Hi
what is the difference between mach3-4(mm) and mach3-4 arcs (mm)?
arcs is generating G02/G03 where possible while the other one will generate a lot of straight line segments approximating arcs.
thx alot,
i have artcam 2018 and mach3,,, so which is better to generate my G code as mach3 arcs(mm) or mach3 (mm)?
mach3 arcs(mm)
