Hello Guest it is October 04, 2026, 04:30:56 AM
Author Topic: tuning motors  (Read 38503 times)
Re: tuning motors
« Reply #10 on: June 09, 2014, 04:34:59 PM »
You can use a single relay to do that, just have all of the drives enable inputs to one side of the contacts and the LG to the other.
Offline sdow
  •  67 67
Re: tuning motors
« Reply #11 on: June 18, 2014, 05:38:51 PM »
Hi hood
I tuned my motor Y  is very good .... but when i add a slave motor Y  .... i really have problem to get same speed ?   can you help  ... my motor 1 is stopped and motor 2  go  5 rpm front ...5 rpm rear ......
thanks
« Last Edit: June 18, 2014, 05:52:43 PM by sdow »
Re: tuning motors
« Reply #12 on: June 19, 2014, 02:52:36 AM »
Afraid I have never slaved a motor  so cant really help except to say it sounds like you have tu8ning issues with the slaved motor. If the motor/drive are exactly the same as the other motor then try setting the PID exactly the same and see if that helps.
Offline sdow
  •  67 67
Re: tuning motors
« Reply #13 on: June 21, 2014, 11:50:04 PM »
Hi hood
I +- finished my CNC  ... but i have a problems with a limit switches ..... when the cmc go and touch the limit switch  ...the cmc stop ... and i can not run it in opposite side  ....i need to remove my limit switch  (manually ) to move my cnc .
thanks
Re: tuning motors
« Reply #14 on: June 22, 2014, 07:17:16 AM »
If you hit a limit switch with the CSMIO you have to jog off via the keyboard, MPG mode does not allow you to jog off.
Offline sdow
  •  67 67
Re: tuning motors
« Reply #15 on: June 22, 2014, 07:58:45 AM »
what i need to click on keyboard to move it
Offline sdow
  •  67 67
Re: tuning motors
« Reply #16 on: June 22, 2014, 09:12:06 AM »
i think it is my problem     form user guide csmio
what is the solution ?   the HV disable my motors if limits is activated ?
10.9.5.2 HV Enable
In this place you can – for any CSMIO/IP con-
troller output – assign a function of main voltage activation (e.g. for servo drives). In many alarm situations like e.g. E-STOP signal activation, additionally main supply disconnection it may increase security level.
Output defined as „HV Enable” will be active during normal work of CSMIO/IP controller, in case of any alarm situations, such as limit switch or E-Stop touch, the signal will become inactive.
Re: tuning motors
« Reply #17 on: June 22, 2014, 03:55:40 PM »
When you hit an E-Stop can you take Mach out of Reset (steady  green LED rather than flashing red)?
Offline sdow
  •  67 67
Re: tuning motors
« Reply #18 on: June 22, 2014, 04:30:38 PM »
non every  time  it detect the switch limit and go into reset
Re: tuning motors
« Reply #19 on: June 22, 2014, 05:37:45 PM »
Go to settings page and choose the Auto Limit Override option and see if that allows you to take Mach out of Reset.
