Hello Guest it is October 24, 2026, 05:14:25 PM
Author Topic: tuning motors  (Read 38862 times)
Offline sdow
  •  67 67
tuning motors
« on: June 06, 2014, 10:47:51 AM »
Hi
When connected my drive to cs-mio/ip-a  .... my motor started to run .... why ? Can you help me ?   When i try to click on auto tuning PID  ... i have error ...ePID....
Re: tuning motors
« Reply #1 on: June 06, 2014, 04:04:06 PM »
Try reversing  the encoder in the plugin, see screenshot.
Offline sdow
  •  67 67
Re: tuning motors
« Reply #2 on: June 07, 2014, 12:10:52 PM »
hu hood
my pid is good when Stop button is not activated my motor mont run ... but when i click on Stop ... the motor start to run +-40rmp/min ?
Offline sdow
  •  67 67
Re: tuning motors
« Reply #3 on: June 07, 2014, 02:24:31 PM »
or when i close  mach3 my motor start to run +-40rmp/min
Re: tuning motors
« Reply #4 on: June 08, 2014, 08:59:53 AM »
Your servo drives should only be enabled when Mach is in control. If they are moving when Mach is in Reset or fully closed then you do not have the servo drives controlled properly.
Offline sdow
  •  67 67
Re: tuning motors
« Reply #5 on: June 08, 2014, 05:59:02 PM »
yes my drive have enable where i need to connect it on cs-mio
Re: tuning motors
« Reply #6 on: June 09, 2014, 12:31:32 PM »
You can either use the enables in Mach itself or use the ones in the CSMIO plu8gin (Misc I/O page)
Offline sdow
  •  67 67
Re: tuning motors
« Reply #7 on: June 09, 2014, 12:35:14 PM »
Can you give me the picture where i can find the configuration for enable the drivers ....exemple i would connect all my drivers to I/O 3 on csmio
Re: tuning motors
« Reply #8 on: June 09, 2014, 12:43:29 PM »
It will depend on what signal your servo drives expect for their enable. If it is simply a positive 24v signal then you could just connect any output to the drive and configure that as an enable in Mach or CSMIO plugin. You can link all drives to the same output if you wish as long as the current draw isnt higher than the max output of the CSMIO (250mA if I recall)
Offline sdow
  •  67 67
Re: tuning motors
« Reply #9 on: June 09, 2014, 01:15:25 PM »
i will probably use the relays    because my SON (enable ) need to connect to LG (GND) of my drivers .... i will use 4 relays each for one drive connected in parallel  to IO3 of csmio
