Hello Guest it is October 22, 2026, 06:22:21 PM
Author Topic: Port 1  (Read 9626 times)
Port 1
« on: May 24, 2014, 05:49:06 PM »
Hi all, I am running into a small problem.  I cant use the normal Port 1 for Mach 3 because it is used up by the mother board.  So I need some guidance as to what course of action I should take
Re: Port 1
« Reply #1 on: May 24, 2014, 07:40:31 PM »
Mach3's Port1 is not the same as LPT1. Just enter the address of the port you want to use for Port 1 in Mach3.
Port 1 in Mach3 can be any parallel port.
Re: Port 1
« Reply #2 on: May 25, 2014, 04:33:32 PM »
GER 21,
Thanks for that tidbit of useful information.  I will use it today
