Hello
Guest
it is
November 13, 2026, 07:03:28 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
computer crashed need HELP!!! transfering data
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: computer crashed need HELP!!! transfering data (Read 23108 times)
Learn
75
on:
April 26, 2014, 01:55:53 PM »
Ok I will try to make this short . I purchased a machine from someone and I got the machine home with everything intact. I turned the computer on a couple of times and then the last time I tried it the computer would not get past the starting page . Prior to this it was working to my knowledge with out any issues . so I try to load everything in and it would not start up. I went to the old owners shop and he looked at the hard drive and he said it was fine . He then backed up my Mach 3 files o a USB jus in case. Now I have another computer ready to use and have loaded te Mach 3 info into the "C" drive. now I power u he machine and it will not ove the machine at all. Is there something that Iam missing ? I have had this machine for a week now and have been unable to get the darn thing to run. now I would use the old Hard drive I n the new computer but the wire set up is way different.
So how do I load al of my parameters in to the new computer so it will work ?
soe one please help before I loose my mind . This is killing me . I don't know what else to do
Logged
Fastest1
920
Houston, TX
Re: computer crashed need HELP!!! transfering data
Reply #1 on:
April 26, 2014, 05:08:23 PM »
Mach doesnt open or it doesnt create movement?
Logged
Learn
75
Reply #2 on:
April 26, 2014, 07:08:58 PM »
It does not make movement . Also I have an error now on my phase converter
Logged
Fastest1
920
Houston, TX
Reply #3 on:
April 27, 2014, 08:53:09 AM »
Do you get power for your PC thru 1 of the legs off of the convertor?
Is your copy of Mach licensed (it should work anyway if set up correctly)?
Did you install the last working xml?
Logged
Learn
75
Reply #4 on:
April 27, 2014, 09:34:31 AM »
As far as I am aware it is licensed to the guy I bought it from. He no longer uses it . XML ? where do I find that?
as far as power I am not sure . I am def not a computer guy just a cnc programmer
Logged
Learn
75
Reply #5 on:
April 27, 2014, 09:35:25 AM »
The converter gets power from the 220 on the wall and then a few wires are connected from the controller .
Logged
Fastest1
920
Houston, TX
Reply #6 on:
April 27, 2014, 06:25:37 PM »
An XML is the profile. It had all of the ports and pins settings contained within.
Logged
ger21
6,295
Reply #7 on:
April 27, 2014, 08:24:52 PM »
If you copy the entire mach3 folder from the old PC to the new one, it should run the same on the new one. The .xml file with the settings should be in the Mach3 folder.
Logged
Learn
75
Reply #8 on:
April 28, 2014, 03:48:19 AM »
Ok I have both the new. Computer and the old hard drive hooked up and both are set up with the mach 3 . I bought the external box for the hard drive just in case . Now I'm thinking I may need to return that box. good news is I have been in contact with the original owner who. Built this thing and we arranged for him to come over today and help get this thing going. Now the only thing I can think of is maybe one if the wires that goes from the cnc controller board to the vdf is not hooked up properly and is faulting it out. When I transported the machine to my house we had to disconnect the wires in order for us to transport it. Looking at the set up their are some dated connectors and almost all of the wires are just ran like spaghetti with no real protection. So I ordered some correlated wire cover to ad protection . I will update all of you as soon as I can . Thanks so far for the replies .
Logged
Fastest1
920
Houston, TX
Reply #9 on:
April 28, 2014, 06:45:36 PM »
The original owners will understand the requirements and have you up and running in minutes. It isn't hard after you are familiar with it. That being said, next week I will be posting a total Noob question.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
