Hello Guest it is November 13, 2026, 07:03:29 AM
Author Topic: computer crashed need HELP!!! transfering data  (Read 23108 times)
Offline Learn
  •  75 75
Re: computer crashed need HELP!!! transfering data
« Reply #10 on: April 29, 2014, 03:45:56 AM »
Ok after talking to the original owner we realized that it may just be a port issue . I went into the config /port pin section and it appears to be correct . . The machine will not jog around still. I'm going to run a new wire from the vdf to the cnc controller as I see that is causing the error on the vdf. That might be the culprit. Original owner rescheduled to see it Wednesday.
Offline Learn
  •  75 75
« Reply #11 on: April 29, 2014, 03:50:35 AM »
The wire is for the logics that will be replaced
Offline Learn
  •  75 75
« Reply #12 on: May 01, 2014, 11:35:56 AM »
well the owner had an unexpected thing pop up and said he may be able to come by today.
I am thinking I need to replace the logics wire that runs from the control to the phase converter. does anyone know what wire I should be using ?
Offline Learn
  •  75 75
« Reply #13 on: May 02, 2014, 03:43:08 AM »
Problem solved!! The original owner came by last night and we tested things for a couple hours  and had to install the software . And run a couple of new wires .!!!!!  ;D now time to wrap things up so I can start cutting .  Thanks for all the replies
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #14 on: May 03, 2014, 08:16:22 AM »
Great to hear the machine is up and running.
Offline Learn
  •  75 75
« Reply #15 on: May 17, 2014, 07:07:31 AM »
we have it up and running now !!! I put all file in my c drive but never installed the drivers   what was I thinking ??? LOL
