Hello Guest it is September 15, 2026, 08:33:50 AM
Author Topic: My X home switch is not backing off after homing this axis.  (Read 20940 times)
« on: January 21, 2014, 09:45:39 AM »
The Y axis still homes and backs off, but the X axis only homes, does not back off the switch any more.
What might cause this. Note, I have not made any changes, this just started happening.
XML posted in this thread (forum prevents posting same twice) http://www.machsupport.com/forum/index.php/topic,26374.new.html#new
Thanks!
Re: My X home switch is not backing off after homing this axis.
« Reply #1 on: January 21, 2014, 09:48:37 AM »
Is there an error message? Is the axis "Ref'd" after it hits the switch? It's only supposed to back up enough for the switch to open.
« Reply #2 on: January 21, 2014, 11:20:16 AM »
The error message only pops up if I attempt to home it again after doing the homing once. The error message is something to the effect of- limit switch is activated, please deactivate limit switch before homing machine.
The only reason I found that it is not moving off the X axis home switch is that you can hear it move off the Y switch, and I did not hear it move off the X switch. Sure enough, when looking at the switch , the x axis does not preform the move off of it.
Any thoughts?
« Reply #3 on: January 21, 2014, 11:55:33 AM »
Does the Ref LED light up?
« Reply #4 on: January 21, 2014, 11:58:47 AM »
Is the ref led the box around the X, Y, Z, or 4 that turns green? (on the program run page)
« Reply #5 on: January 21, 2014, 12:09:04 PM »
yes
« Reply #6 on: January 21, 2014, 12:12:38 PM »
I am not in front of it, but I remember that the Y RefLED will turn green and the X RefLED does not.
So, does that mean it is not completing homing the X even though it is tripping the switch? I know the switch is being activated as it stops at it and the M1Home and M2Home leds on the diagnostics page are both lit after homing.
« Reply #7 on: January 21, 2014, 04:32:56 PM »
I take it back. The ref leds indeed do turn green, both Y and X.
« Reply #8 on: January 21, 2014, 06:47:46 PM »
A bad switch (contact bounce)?  Try changing it.
John Champlain
« Reply #9 on: January 21, 2014, 07:59:43 PM »
Yes, it sounds like the switches is opening and closing again.
