Hello
Guest
it is
November 13, 2026, 02:59:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
My X home switch is not backing off after homing this axis.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: My X home switch is not backing off after homing this axis. (Read 21624 times)
natefoerg
183
Re: My X home switch is not backing off after homing this axis.
Reply #10 on:
January 21, 2014, 09:11:45 PM »
I replaced the switch with an identical one. These are very expensive Square D push roller style switches.
Same problem. Actually, when I tested the new switch by temp soldering it it worked again, when I perm soldered and heat shrunk, same issue...
Tried debounce of 200.
I dont get it.
Logged
Overloaded
4,923
Reply #11 on:
January 21, 2014, 10:54:37 PM »
You might try a de-bounce of 1000. (or more)
Be sure the homing speed is relatively slow to avoid a crash.
Might prove, or disprove a raggedy switch.
Is the mounting rigid and vibration free ?
Possibilities ?
Russ
Logged
natefoerg
183
Reply #12 on:
January 22, 2014, 09:22:15 AM »
Well, it turns out that I was not actually adjusting the debounce right.
I was in the SS page, but was changing the debounce for LIMITS, not HOME. Once I changed the HOME debounce, the problem dissapeared....
Thanks everyone!
Logged
ger21
6,295
Reply #13 on:
January 22, 2014, 10:06:16 AM »
This goes for everyone reading this. When you post a question, and you're not using the parallel port, then please be sure to specify the motion device your using. It usually makes a big difference in answering the question.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
