Hello Guest it is November 13, 2026, 02:59:13 AM
Author Topic: Wizards OD arc help  (Read 22482 times)
Offline Rimmel
  •  284 284
Wizards OD arc help
« on: January 20, 2014, 01:58:59 PM »
I tried the OD arc wizard and it gives me an arc in G03 code. On my denford easiturn (front tooling) it's the opposite of what i want. Can you force the OD arc to use G02 instead of G03. I have searched by cant find anything.
thanks
Re: Wizards OD arc help
« Reply #1 on: January 20, 2014, 02:22:44 PM »
Reverse arcs in front post option not work?
Offline Rimmel
  •  284 284
« Reply #2 on: January 20, 2014, 02:32:42 PM »
Where is that option, I've been looking all over.
thanks
« Reply #3 on: January 20, 2014, 02:38:30 PM »
Config menu, Ports and Pins, Turn Options.
Offline Rimmel
  •  284 284
« Reply #4 on: January 20, 2014, 02:43:49 PM »
I'll have a look - thanks
Offline Rimmel
  •  284 284
« Reply #5 on: January 21, 2014, 08:18:43 AM »
Checked and the option was already ticked. So un-ticked it and the wizard code does not change (still using G03). However the path generation now looks like this:
« Last Edit: January 21, 2014, 08:21:55 AM by Rimmel »
« Reply #6 on: January 21, 2014, 08:45:24 AM »
Change the IJ mode in General Config.
Offline Rimmel
  •  284 284
« Reply #7 on: January 21, 2014, 09:25:34 AM »
Thanks - tried all combinations, it will not change from G03.
« Reply #8 on: January 21, 2014, 09:39:42 AM »
The code itself will not change but the toolpath should show correctly.
Double check you have the tooltable set to Front if that is what you are using as if its set to rear then it will not reverse on front arcs.
If that doesnt help attach your xml and let me know the settings you are using in the wizard.
Having said that I have not tried the wizard so maybe I better ;D
« Reply #9 on: January 21, 2014, 09:54:14 AM »
Ok had a look, seems to be the wizard is Rad mode, why anyone would prefer Rad mode is beyond me but seems big in the USA.
