Hello
Guest
it is
November 13, 2026, 02:49:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Wizards OD arc help
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Wizards OD arc help (Read 22474 times)
Carnoustie, Scotland
Re: Wizards OD arc help
Reply #10 on:
January 21, 2014, 10:49:43 AM »
It does actually seem to work in Dia mode, must have just been a setting I had changed from within the wizard didnt stick.
Anyway settings I have that are working are
Dia mode
Reversed Arcs in Front
Tool in table set to Front.
Logged
Rimmel
284
Reply #11 on:
January 21, 2014, 01:17:34 PM »
EEK!
Thanks Hood, will give that a try.
Appreciated!
Logged
Rimmel
284
Reply #12 on:
January 22, 2014, 06:09:56 AM »
Mine is set exactly the same - however it will only output G03 code. It will not output G02.
very perplexing.
Logged
cncalex
244
Reply #13 on:
January 22, 2014, 09:31:11 AM »
There is no option to reverse the cutting direction as I see.
Alex
Logged
Reply #14 on:
January 22, 2014, 09:35:16 AM »
It does output G3's, it should still be correct.
Please attach your xml and also what version of Mach are you using?
Logged
Print
Pages:
1
2
Go Up
« previous
next »
