Hello
Guest
it is
November 22, 2026, 06:41:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
PWM Base Frequency
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PWM Base Frequency (Read 11820 times)
kolias
1,165
PWM Base Frequency
on:
January 06, 2014, 07:24:47 PM »
On Figure 5-7, page 5-11 of Mach3 manual, under Motor Control, what numbers normally do you put for "PWM Base Frequency" and "Minimum PWM"?
I can't find this info anywhere in the manual
Logged
Nicolas
Carnoustie, Scotland
Re: PWM Base Frequency
Reply #1 on:
January 07, 2014, 01:04:37 PM »
I think these values would depend on the hardware you are using but then again I have never used PWM so take that with a pinch of salt
Logged
HimyKabibble
1,687
Reply #2 on:
January 07, 2014, 01:47:19 PM »
PWM frequency is typically 50Hz. Little to gain by going faster, and it can reduce resolution, depending on your kernel speed.
Logged
kolias
1,165
Reply #3 on:
January 07, 2014, 02:11:26 PM »
I will use 50Hz, thank you both
Logged
Nicolas
Print
Pages:
1
Go Up
« previous
next »
