Hello Guest it is November 23, 2026, 02:33:54 AM
Author Topic: The image gets flipped (mirror)  (Read 10999 times)
« on: January 02, 2014, 05:17:07 AM »
I'm new at this...
I have a problem with a picture that should be pointed to the left but when the Mach3 has done it's job it is pointing to the right?
Why? Can you tell me exactly how I can make it work right?
Thanks!
Finland
Re: The image gets flipped (mirror)
« Reply #1 on: January 02, 2014, 06:03:41 AM »
Finland,
It sounds as though your X axis (left/right) may be operating reversed.  Try reversing the Dir LowActive setting in Ports and Pins.
John Champlain
« Reply #2 on: January 02, 2014, 08:48:27 AM »
Okay...
It's now on a number 1 should it be -1?
Thanx..
  •  9,378 9,378
« Reply #3 on: January 02, 2014, 09:57:05 AM »
This is the area John was referring to.
« Reply #4 on: January 02, 2014, 11:33:24 AM »
Okay!
So Dir LowActive X and Y should be red and then it should work fine?
And i Have a CNC3040 so i need only the X Z Y so it will work fine?
Thanx alot man!
  •  9,378 9,378
« Reply #5 on: January 02, 2014, 11:39:07 AM »
NO - that is not what John suggested - just change the existing state for your X axis.
« Last Edit: January 02, 2014, 11:47:24 AM by Tweakie.CNC »
