Mach Discussion => General Mach Discussion => Topic started by: SirFinland on January 02, 2014, 06:17:07 AM
I'm new at this...
I have a problem with a picture that should be pointed to the left but when the Mach3 has done it's job it is pointing to the right?
Why? Can you tell me exactly how I can make it work right?
Thanks!
Finland
Finland,
It sounds as though your X axis (left/right) may be operating reversed. Try reversing the Dir LowActive setting in Ports and Pins.
John Champlain
Okay...
It's now on a number 1 should it be -1?
Thanx..
This is the area John was referring to.
Okay!
So Dir LowActive X and Y should be red and then it should work fine?
And i Have a CNC3040 so i need only the X Z Y so it will work fine?
Thanx alot man!
NO - that is not what John suggested - just change the existing state for your X axis.
