Hello Guest it is November 26, 2026, 09:51:57 PM
Author Topic: Setup table dimmension with gcode file.  (Read 19974 times)
« on: December 28, 2013, 03:54:52 PM »
Having a little problem, when i load my gcode into mach 3 looking at the tool display window the part is outside of my table in display window.
I know it has to be something that is not set up correctly with my inputs could someone look at the attached screen shots and see if they can see something that is not correct.
I have my home set up with table to the front and to the right.
push the right arrow and table will move to the left and push the up arrow the table will move to the front.
Re: Setup table dimmension with gcode file.
« Reply #1 on: December 28, 2013, 04:07:05 PM »
Just jog to centre of table then zero the X and Y DROs then Regen and see if that helps.
« Reply #2 on: December 28, 2013, 04:10:50 PM »
I think your Y Max should be 132 and the Min 0.00     ...  Very similar to the X settings.
« Reply #3 on: December 28, 2013, 04:19:01 PM »
I noticed that 132 and when I changed it to match the x settings. The punisher comes out upside down.
« Reply #4 on: December 28, 2013, 04:30:42 PM »
corrected home
« Reply #5 on: December 28, 2013, 04:37:17 PM »
put 132 in the Y Home Off box.
Then you will be setup with 0,0 in the proper direction.
Russ
« Reply #6 on: December 28, 2013, 04:51:35 PM »
changed to 132 but when i went back into it was changed to 5.19
then the punisher is out side of the box.
when i try to re zero manual by moving the axis I can not go in the direction to bring it within the window.
The y axis hits the front of the mill past the home switch.
« Reply #7 on: December 28, 2013, 05:16:38 PM »
I moved it the punisher to a different section of cambam and up loaded gcode and it fell right on to the table in the display window
« Reply #8 on: December 28, 2013, 05:57:59 PM »
Forgot to say thanks for your help OverLoaded.
John
« Reply #9 on: December 29, 2013, 08:09:48 AM »
Maybe you need to try and get an understanding of work offsets ;)
