Hello Guest it is October 23, 2026, 09:49:09 PM
Author Topic: Consistent stepper clunking. All axis' all the time  (Read 31501 times)
Re: Consistent stepper clunking. All axis' all the time
« Reply #10 on: December 29, 2013, 07:30:27 AM »
hopefully someone will figure out what is the cause of this noise. I have just picked up 8 dell optiplex gx620 desktops and i've loaded xp and mach3 on all, on the first four two have the noise issue and two are fine...strange.
« Reply #11 on: December 29, 2013, 07:31:03 AM »
In the bios, disable C1E or EIST if you have them. Also, disable any unused hardware in the bios.
I'll try that today.
« Reply #12 on: December 29, 2013, 07:32:28 AM »
I also have six novatech ibm clones with the same problem, i'll try them when i've finished the current conversion.
« Reply #13 on: December 29, 2013, 08:04:19 AM »
Make sure ACPI is set to standard on all of them. I know the OP has it this way.
I run an old $20 GX150 and it needs ACPI set to standard to run smoothly.
