Hello Guest it is October 21, 2026, 08:03:28 AM
Author Topic: Writing code  (Read 7720 times)
Writing code
« on: December 23, 2013, 02:47:37 PM »
I have a part im making . In the center of the part it holds a bearing. Above that bearing is a lock ring to keep it in place. How do I  go about write a code so I can use my slitting saw to make a spot for the lock ring to fit.
Re: Writing code
« Reply #1 on: December 24, 2013, 02:02:25 AM »
You could likely use a G12 or G13. for example if you move down in the centre of the hole the do a G13I5 it will move out in X by 5 units then cut round in a circle of 5 units radius and then finally move back to the centre.
