Hello
Guest
it is
October 21, 2026, 03:14:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Writing code
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Writing code (Read 7718 times)
mrich0908
68
Writing code
on:
December 23, 2013, 02:47:37 PM »
I have a part im making . In the center of the part it holds a bearing. Above that bearing is a lock ring to keep it in place. How do I go about write a code so I can use my slitting saw to make a spot for the lock ring to fit.
Logged
Carnoustie, Scotland
Re: Writing code
Reply #1 on:
December 24, 2013, 02:02:25 AM »
You could likely use a G12 or G13. for example if you move down in the centre of the hole the do a G13I5 it will move out in X by 5 units then cut round in a circle of 5 units radius and then finally move back to the centre.
Logged
Print
Pages:
1
Go Up
« previous
next »
